Hello,
Is there a way to remove the corner page flip (when clicked on the bottom corner of a page) and only keep the arrows the flip through?
Hello,
Hi there, @Sabrina_Da_SIlva ![]()
Thanks for the idea!
At the moment, it’s impossible to disable this flip option. However, if more users upvote this idea, we’ll try to think about it ![]()
I would also like to see this feature implemented. I have links in the bottom corners of my PDF that become unclickable when the corners of the page are hovered and it animates. Is there any solution to this in the meantime? @Max Thank you!
Welcome to the Community, @Carly_McIntyre ![]()
Thanks a lot for your comment!
Unfortunately, there is now way to implement a custom solution now, I am really sorry!
However, I completely get your case and agree that it would be awesome to have this option available. Let’s hope this idea gets more traction with others and the devs will be able to consider it down the line ![]()
Thank you for getting back to me so quickly! No problem, I’ll keep an eye out for any future updates. @Max
