while crwaling linkedin post - it took around 48 hours to post through elfsight widget. Kindly try to reduct that time. you can charge extra to quick updates. but that feature should be there.
Welcome aboard
I totally understand your point. This task is quite complicated and I am afraid I can’t promise that the cache time will be reduced. However, we’ll definitely try to find a solution for this!
A huge thank you for your input
To follow up on this? I didn’t realize there was a delay. We had a “scheduled post” that posted on October 23 and it has yet to show up on the LinkedIn feed. Is there a several day delay?
Yes, the cache time for LinkedIn Feed widget is 48 hours.
If it’s been more than 48 hours and you’re still not seeing the new posts, please share a link to the page where your widget is installed. I’ll gladly check it for you
