Recommend products
That can recommend products with the connection of an XML to customers
Hi @Juventino_Landeros, great to see you in the community! :wave:t2:
It seems you’re looking for a widget that can suggest a specific item (or product) based on certain steps a customer has taken. Is that correct?
And could you please describe your use case in some more detail? That would be really helpful!
