Pull reviews from Pure Local Business Directory
And also for Pure Local Business Directory - they just accepted our listing , yuss.
Hi there, @user23833 :waving_hand:
Thanks for the idea! We can’t promise that such a source will be definitely added, but if it gets more votes, we’ll try to think it over :slightly_smiling_face:
As a workaround, you can use a Custom Source option in our All-in-One Reviews app and add the needed reviews manually. Feel free to check it out:
Thank you so much for sharing your feedback with us!
Thanks for this Max, great idea to try the All-in-one widget, will do that. Would be great to get the rest of the world URLs working with Houzz at it’s heavily used in the UK, Australia etc!
Actually, I’ve just noticed that if you set Houzz to United States in the Houzz footer then it gives you a .com URL.
Hi @Sara_Watkins :waving_hand:
Thank you for the feedback!
Could you please specify what Houzz footer you mean?
