Product configurator 2D
13 different picture and 60 pads to change. :sweat_smile:
Hi there, @Jan_Poliach and welcome to the Community :wave:
Could you please describe how this app should function? What features would you like to see in this app? Do you have an example of a similar existing app?
Hi. I search whole internet about mont and this widget doesn’t exist.
Funcionality i mean its simple. The customers have choice from 13 color breed american quarter horses. And then he may choice from 60-100 pieces western show pads to bring on one choosed color breed horse. I mean its 2D configurator…maybe doesn possible made as widget. I dont know. Thanks. Jan.
Dňa št 6. 3. 2025, 19:02 Max via Elfsight Community <notifications@elfsight.discoursemail.com> napísal(a):
Got it, thanks!
You see, we create widgets that might be helpful for many users. Your use case is quite custom, and it goes beyond our general widget concept. So, I am afraid, we won’t be able to release such an app in the future.
If you have any questions or suggestions for our existing apps, we’re always here to help :wink:
Hi, thank you for answer, its ok i undestand. I will have custom 2D configurator, but its expensive. That cost my year salary because i am small hand made factory.
Have a nice day. Jan.
Dňa pi 7. 3. 2025, 12:31 Max via Elfsight Community <notifications@elfsight.discoursemail.com> napísal(a):
