Problem with mobile pagination buttons
Hi,
I used code from this forum:
@media (min-width: 100px) {
.es-layout-comparison-table-snap-carousel {
grid-template-columns: unset;
grid-auto-columns: 200px;
.es-widget-container {
–head-column-width: 180px;
.es-layout-comparison-table-outer-table-container,
.es-layout-comparison-table-container {
grid-auto-columns: calc((100% - var(–head-column-width)) / 2);
grid-template-columns: var(–head-column-width);
.es-layout-comparison-table-snap-carousel .es-head-column-container * {
max-width: var(–head-column-width);
.es-snap-carousel-arrow-control-container:has(.es-snap-carousel-arrow-control-left) {
left: calc(var(–head-column-width) - 16px) !important;
but after that i get this problem:
and the my next question:
Is it possible to make the pricing table wider and responsive to window size? Currently, even on widescreen monitors, only a few columns are visible. It should work so that someone who opens fullscreen on a widescreen display can see all columns, while someone with a laptop sees only as many columns as fit their resolution. The table should automatically adjust its width based on the browser window size.
Hi there and welcome to the Community, @Grzegorz :waving_hand:
I’ve forwarded your request to the dev team and will let you know once I have any news :wink:
Hi there, @Grzegorz :waving_hand:
I’ve consulted with the devs and the only option here is to make the widget full width:
On narrower screens it’s impossible to fit all columns, but with the Full Width option enabled all columns will appear right away on wide screens.
