Possibility to add reviews from https://www.hostelworld.com/
It would be a great addition to your product!
Hello @Ben_Onefam :wave:
Thank you so much for adding your idea to the Wishlist!
If more users support the idea of adding this source, we’ll try our best to consider this opportunity :slightly_smiling_face:
