Place arrows higher
Add this code to the Custom CSS field on the Appearance tab of your YouTube Gallery widget’s settings:
div.yottie-widget-feed-section-arrow {
top: 110px !important;
margin-top: 0 !important;
@Max is there a way to place the arrows completely underneath for mobile?
Unfortunately, it’s impossible to move the arrow under the videos, but you can place at the very bottom of the video using this code:
@media (max-width: 500px) {
    bottom: 0;
    top: unset;
No worries Max! thank you!!
