Pin testimonials
Hello, I was wondering if there was a way to pin a few to the top and then shuffle all the rest of them I know there’s a random feature for all of them, but I don’t mind having a select few seen first from over the years on top.
Hi there, @Rev_Devan :waving_hand:
At the moment, you can manually change the order of the testimonials using drag and drop option. So, you can manually move the featured testimonials to the top.
Does this option cover your use case?
