Past Event Automation
Would like to have some options to automate changed in appearance to past events such as:
  • Change custom event color
  • Hide button to close RSVPs
  • Image overlay to indicate event has passed
Hey there @Vivian_Snyder :wave:
Our devs came up with the custom codes for your case:
1. Hide buttons for the past events:
.eapp-events-calendar-layout-past-event .eapp-events-calendar-button-element-component {
  display: none;
2. Change background and text color of the past events:
.eapp-events-calendar-layout-past-event .eapp-events-calendar-grid-item-component {
  background: rgb(178, 17, 17);
.eapp-events-calendar-layout-past-event .eapp-events-calendar-grid-item-info * {
  color: rgb(255, 255, 255);
3. Change image overlay:
.eapp-events-calendar-layout-past-event .eapp-events-calendar-media-image {
  filter: brightness(0.2);
Add these codes to the Custom CSS field on the Appearance tab and let me know if you like the result :slightly_smiling_face:
Hi Max!
Thank you so much! This worked perfectly!
Awesome! You are very welcome :wink:
