Parallax effect for more elements
It would be great to have the option to apply the parallax effect to additional types of elements, not just background images.
Hi there, @user17273 :waving_hand:
Could you please send me a link to the page, where your widget is installed and specify the elements, where you’d like to add a parallax effect? I’ll be happy to check if there is a custom solution :slightly_smiling_face:
