I have about three widgets used on a website (https://www.theetiquettemethod.com)
- Two pricing table widgets
- One LinkedIn Recommendations widget
- One Customer journey widget
At first, I had excessive padding around the widget which could not be resized. So I followed the first bit of advice for 7.1 editor here: Why my widget has an extra padding on my Squarespace website - Elfsight Help Center
That worked however, however it did not reduce the padding just around the widget, but of the whole Squarespace section. So I had to re-create surrounding sections so things would be spaced properly.
Ever since adding in that code-fix, it caused problems with the Squarespace site overall. The vertical and horizontal points from which you can resize images/text boxes often breaks, and changing section sizes also became an issue.
So, I try to use the Classic Editor solution as advised in that article and that works in preview mode. The code was copied and pasted in again correctly into a new </> code block, now those widgets do not display AT ALL on the live website and nor on mobile.
On the back-end Editor mode in Squarespace, all code blocks jut say ‘Script disabled’. Why?
As you cans see with all the blank spaces where the widgets should display. They displayed momentarily when I used the Classic Editor section fix, but then they stopped displaying.
Really frustrating issue!
What’s the problem?
