Doesn’t seem to work for me. see image
Hi there, @user8320 ![]()
Could you please specify the name of your Form Builder widget where the issue occurs?
Reparatie v2
Hi @user8320! I’ve checked your widget, and I believe it works just fine.
You see, if you need the “Or” logic, just choose “any” instead of “all” in the Action filed:
With “any” enabled, it will work as “Or” option.
Let me know if it helped ![]()
@user8320 , thank you!
Yes, there was an issue on our end indeed, my apologies for that. We’ve updated your widget so it should work fine now ![]()
Could you please check it once again?
