If you want to publish a collection of images (e.g. house renovation), you may want to show individual images without the function (e.g. only “After”) in addition to the “Before/After” images. Although you can simply load just one image here, in this case you should also be able to hide the slider for this image individually, i.e. you should be able to determine the slider setting for each element of the widget and not just for the entire widget. The attached image shows the situation of two houses after conversion (without “before/after”) in a collection of “before/after” images (not shown). Here it should be possible to set the slider individually to “Hide”
Interesting idea! Let’s see what other users think about this feature
