Option to have a button click register as a close
I have a pop set to Show every time, until I close it and also a button that takes you to another page.
It would be good if there was an option to make the button register as a close (as well as going to the page). Then it wouldn’t pop-up again.
@user2432 great suggestion, many thanks for sharing!
I hope this is not something too complex, and our devs will be able to consider your request in the future updates. And if other users get interested in such an option, it could also speed up the process :slight_smile:
Thanks a lot for your help, and welcome to the Elfsight Community! :tada:
Hi, is there a way to make the popup link to close the popup itself?
Hi @Eric_Niceberg, thank you for your suggestion!
Do you think this idea reflects yours: Option to have a button click register as a close? If so, I’ll be happy to merge them together :slight_smile:
Hi Helga,
Yes, it looks like the same idea :slight_smile:
Great! I’ve merged them so that you can follow all the updates which I’m going to post in the thread when we start working on this request :slight_smile:
Thanks a lot for your help!
