Option to adjust number of columns on grid
Original Votes: 2
I would add to this request by allowing any odd grid items where 1 or 2 cannot fit on the line specifically to be centered rather than just off to the one side… It feels uneven when you have 3 on one line 1 or 2 on the bottom but an open space next to it.
I too request to have smaller “squares” for each employee just to get 5 in a column.
Hello friends, @KeyframeKreations, @user3708 :waving_hand:
Thank you for your feedback!
Just in case, I’d like to note that you can change the number of cards displayed by changing the width value in the settings:
If you’d like to keep your widget width and make the member cards smaller, you can do this using a code in the Custom CSS field on the Style tab of your widget’s settings. :slightly_smiling_face:
3 cards in a row on desktop:
@media (min-width: 500px) {
.eapp-team-showcase-grid-item {
width: 30% !important;
5 cards in a row on desktop
width: 20% !important;
Unfortunately it’s impossible to display more than 2 members per row on mobile in a neat way. If 2 members option works for you, feel free to use this CSS code for the mobile version:
  max-width: 25%;
.eapp-team-showcase-member-card-info-component {
  max-width: 100%;
@media (max-width: 700px) {
    max-width: 50%;
Hi Max, thanks- it looked great on the web, but it looked terrible on mobile. Suggestions!
Hi there, @user3708 :waving_hand:
You’re right, unfortunately it’s impossible to display more than 2 members per row on mobile in a neat way. If 2 members option works for you, feel free to use this CSS code for the mobile version:
  max-width: 25%;
  max-width: 100%;
    max-width: 50%;
And here is the adjusted code to display 5 members per row on desktop only:
