Mobile UX Upgrade Suggestions
Please take this under consideration and you will see it makes a lot of sense on Mobile and would make ALL the difference on user experience (by logic)
  1. The Locations list is hidden by default.
  2. User makes a search on the search box.
  3. Results listed after the search!
  4. a maximum of 4 or 5 results and then the arrow pointed down (not up/above) to show the complete list.
@Daniel_Monteiro Thank you so much for sharing your suggestions!
We’ll try to take them under consideration in the future and I’ll make sure to inform you here in case of any news :slightly_smiling_face:
