Medical needs (tablets, injections, etc)
A small calendar type widget which can showcase no of tablets are available till the particular date. It should be like a calendar and have small tick marks under it
Hi there, @You_Me :waving_hand:
Thank you so much for the idea!
Do I get it right that you have e-pharmacy and you’d like to show a calendar with the number of available medications? If so, are you going to add the info about available medications manually or the widget should automatically pull this info from a specific database?
