Manually Add in Location
Not everyone’s google page works efficently, can we manually add in locations?
Hi there and welcome to the Community :wave:
Unfortunately, there is no way to add the location manually without specifying your Google Business Name and Address.
I see that it would be a nice addition and we’ll try to consider this opportunity in our future updates :slightly_smiling_face:
As for now, could you please provide more details about the specific locations where you are experiencing difficulties with the addition? I’ll be happy to look into this for you!
Hi max!
I have a google location that isn’t working! Aleena Kanner is the name of my business
Also yea- manual add would be amazing.
I am trying to make a practitioner portal and a lot of the practitioners that I work with do not have a Google business so I don’t know what other store locator I could use but a lot of these people such as therapist or body workers don’t have a Google business and even people that are doing their business virtually
So I don’t know if any sort of manual ad would be something that we could do but I think it would be awesome
Hi @Aleena_Kanner :wave:
I’ve checked your Google Business and see that it doesn’t have a physical address:
In this case, I am afraid there is no option to display your business through the widget as it should have a physical address.
I hope this explains things.
As for the option to display businesses which aren’t registered on Google, I am afraid, this is quite a tall order at the moment. Anyway, we’ll try to take it under consideration in our future updates.
I’ll keep you posted here :slightly_smiling_face:
I would really like the ability to add locations manually too, this would be to use the store locator to replicate our listings (Let’s Go Peak District directory) into blog posts in a visually nice way. Currently we use Longitude and Latitude to place our pins. Would this be also possible as a workaround method.
Hi there, @Phil :wave:
Thank you so much for pointing us in this direction!
As for the adding locations by longitude/altitude, we already have such a request. You can upvote it here :slightly_smiling_face: - Add locations by pindrop or altitude/longitude
Not sure if this is still a thing, but I’m using the store locator since last week and am adding stores kind of manually. There are two options:
  1. Upload through CSV - The store locator adds the addresses that you have specified in the CSV. It doesn’t ask for additional google connections and it even points it out on the map correctly. You can add any specifics manually afterwards.
  2. You search the address and you select the address nearest to the location. Then you just change the name and other details manually.
Hi there, @Zlatko_Tanovic and welcome to the Community :waving_hand:
Great note, thanks a lot for sharing it with us!
Hey guys, @Phil, @Aleena_Kanner! Could you please check the workaround suggested by Zlatko and let us know if it covered your needs?
Friends, we’ve started working on this feature and it’s in the Design stage now :tada:
We’ll keep you posted on the further progress here :slightly_smiling_face:
Status update: the feature moved to the Development stage :tada:
Hey everyone!
We’re happy to share that now it’s possible to add locations manually :tada:
Find more details in this post: Store Locator: [MAJOR UPDATE] Add locations manually, custom markers, additional images + 2 more features!🔥
