Loan calculator
I work for a farm lending company and we are wanting to put a loan repayment calculator on the website but I am having trouble getting the code to work. We want the customer to input a dollar amount, number of years there loan will be repaid over, interest rate and be able to select monthly, quarterly, semi-annually and annual payment options. Any help would be appreciated.
Hi there and welcome to the Community, @user28258 :waving_hand:
I’ve tried to create a test calculator based on your request. Please check it out and let me know if it works the way you need :slightly_smiling_face:
Yes! that works the way we are wanting. Is there a way I could edit the colors and style of it?
Great! I see that you haven’t created the widget in your account yet.
Please create a Calculator widget in your account. Once this done, I’ll be happy to transfer the version I’ve shared from my test calculator to your widget.
As for the color, you can modify the widget’s appearance using the settings on the Style tab:
Additionally, feel free to check the Calculator CSS codes category for more advanced customizations.
In case, you haven’t found a needed option in the settings or CSS codes, please describe your idea. We’ll be happy to implement it for you :wink:
Thanks, I have created a calculator widget on my account.
Thanks again.
Done! The settings from the test widget were transferred to your calculator.
Check it out and let me know if everything is fine :slightly_smiling_face:
