Load More Button
I have over 100ish profiles to showcase, i only want to show 4 profiles at a time and add a load more button below to expand the profiles to show more. I have added my css and js code and it is not working? Can you assist in this.
Hi there, @Erb_Rose :waving_hand:
We’ve added this code to the Custom CSS field:
.es-load-more-btn {
    display: block;
    margin-top: 10px;
    padding: 10px 20px;
    cursor: pointer;
    border: none;
    background-color: #007bff;
    color: white;
    font-size: 26px;
    margin-left: auto;
    margin-right: auto;
    transition: color 0.2s ease;
    border-radius: 5px;
And this script was added to the Custom JS section:
  new Promise((res) => {
      if (element) {
        res(element);
        observer.disconnect();
    observer.observe(root, {
      childList: true,
      subtree: true,
waitForElement(".eapp-team-showcase-grid-component").then(() => {
  const containers = document.querySelectorAll(
    ".eapp-team-showcase-grid-component",
  containers.forEach((container) => {
    if (container.dataset.loadMoreInitialized) return;
    container.dataset.loadMoreInitialized = "true";
    const items = container.querySelectorAll(".eapp-team-showcase-grid-item");
    const LIMIT = 4;
    if (items.length <= LIMIT) return;
    for (let i = LIMIT; i < items.length; i++) {
      items[i].style.display = "none";
    const loadMoreBtn = document.createElement("button");
    loadMoreBtn.innerText = "Load more";
    loadMoreBtn.type = "button";
    loadMoreBtn.classList.add("es-load-more-btn");
    loadMoreBtn.addEventListener("click", (e) => {
      e.preventDefault();
        items[i].style.display = "";
      loadMoreBtn.remove();
    container.after(loadMoreBtn);
Please check your widget and let me know if you like the result :wink:
We also have a Wishlist request to add the Load More button control to the settings. Feel free to upvote the idea if you’d like to see the feature released :slightly_smiling_face:- Load more button
Thanks, Max!
How to modify so it only shows 4 more each time, then you need to click the load more button to see more making this action continuous?
Sure, we’ve adjusted your script:
      if (element) {
        res(element);
      childList: true,
      subtree: true,
    const INITIAL_LIMIT = 4;
    const LOAD_BATCH = 4;
    let visibleCount = INITIAL_LIMIT;
    if (items.length <= INITIAL_LIMIT) return;
    for (let i = INITIAL_LIMIT; i < items.length; i++) {
      e.preventDefault();
      const nextLimit = visibleCount + LOAD_BATCH;
      for (let i = visibleCount; i < nextLimit && i < items.length; i++) {
      visibleCount = nextLimit;
      if (visibleCount >= items.length) {
Check it out and let me know if it’s working fine :wink:
Amazing!! Thank you :slight_smile:
Awesome, you’re most welcome!
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 6-month extension for your subscription - February Contest: Guess What’s Missing in Our Photo and Win 6 Months FREE! :wrapped_gift:
