Load More button isn't visible in Social Feed
Allow me to follow up with a question, on masonry dark mode using the social feed, it seems the “load more” button isn’t visible anymore, or just barely. Is it a bug ? What custom CSS can I use to target that button and style it so that it’s visible ?
Hi there, @anthonysalamin :waving_hand:
You can change the button and text color in the Load More Button section on the Appearance tab of your widget’s settings:
