Hi, the “load more” button has disappeared from this app, on mobile view my visitors are now only seeing 5 reviews (fixed by how many rows I have selected to display) and cannot load any additional reviews, can you please add the “load more” button again as soon as possible as this is impacting the amount of enquiries I am receiving. Thanks
Hi @Mark2 ![]()
I am deeply sorry for all the frustration caused!
I’ll be happy to check things! Could you please provide me with a direct link to the webpage where the widget is installed?
Thanks for the quick reply
The Load More button has disappeared from all the websites I am using it on, two examples are below:
@Mark2 Thank you so much!
We’ve forwarded your request to our devs and, hopefully, they’ll come up with a solution really soon ![]()
Please do not worry, I’ll keep you updated ![]()
Thanks, looks like it’s all sorted!
@Mark2 Yes, the issue was fixed!
I am happy to hear that you are good now!
If any questions come up, please do not hesitate to contact us.
