Linkedin widget is disconnected everyday
Hi there! I’ve completed the setting on Linkedin widget, but it keeps being disconnected when I open the browser every time. And it shows up the widget sample instead as attached file that makes me need to connect my Linkedin link manually every time. What can I do to fix this?
Hi there, @user26928 and welcome to the Community :waving_hand:
You’ve added the widget to your website through the Wix integration, right? If this is the case, we have a bug with the integration when the widget displays default content in the website editor.
I’m so sorry for the inconvenience :pensive_face:
We have started investigating this bug and I hope the devs will come up with a solution soon.
In the meantime, you can still use the widget on the website. After you publish the widget on the page it will display the correct settings. The bug should appear only in the editor :slightly_smiling_face:
Thanks for the update! As I’m using the free plan which provides 200 views/month, I would like to know what would the widget happen after it reached 200 views?
Hi @user26928 :waving_hand:
When your views limit is over, the widget on your website will be deactivated. So the widget will not be visible to your website visitors until the next reset date.
Before your views limit runs out, you’ll get several notification email, so deactivation won’t come as a surprise.
When the deactivation happens, you can either:
  • wait for your next views reset date - the views are reset every month
  • or upgrade your plan
Just FYI, here’s an article that will explain the views metric in greater detail - Views: everything you need to know.
Please let me know if this explains things or if you have more questions :slightly_smiling_face:
