Issue description: LinkedIN Posts not showing since May 15
We had this issue back in April and it was resolved. Can I get assistance with this again?
Hi there, @Angela_Weise ![]()
I’ve just readded the LinkedIn source to your widget and the latest posts have been collected. Please check your widget and let me know if everything is fine ![]()
Thanks Max, it’s working. I appreciate your prompt response!!! ![]()
You’re very welcome ![]()
