Layout Problems Instagram Feed
just one more thing:
the problem must come from the widget as the problem is gone once i delete the elfsight-app-Container:
after deletion of the feed:
hmm… weird.
@Renzo_Smania The issue was caused by the CSS code for the Instagram Feed widget you’ve added to your website styles.
As you can see from the screenshot, you’ve set 110% width for the gradient element between the latest post and Load More button. To fix the issue, you just should change the width value to 100%.
Please try it out and let me know if it helped :slightly_smiling_face:
omg i’m so sorry. this seems to have fixed it…
Thank you very much!
No problem at all!
If anything else comes up, we are always here to help :wink:
Good Job @Max ! :slight_smile:
