Instragram feed not 100% width
I am using this widget on a showit website. I have set the widget to 100% but it is still displaying at 1200. And yes I have asked showit about it. They say it is an elfsight problem.
(https://watsonconstructionsfnq.com.au/)
Hi there, @user21883 :wave:
I see that my colleague Renata has already reached to you in a support ticket and informed that the issue is fixed. Please check your website and let us know if everything is fine on your end :slightly_smiling_face:
I will reply to Renata. Thanks but this issue has not been fixed
Thanks
Tony
Tony Reis | ReisDesign
Oh, apologies about that! Renata will double-check the solution with the devs and get back to you :slightly_smiling_face:
