Klaviyo integration
Need Klaviyo integration
Original Votes: 3
Hi,
Thank you for your suggestion!
We’ll try to think over Klaviyo integration and hopefully, we’ll find a way to add it in our future updates :slight_smile:
Thanks a lot for helping us!
Please also integrate the subscriber list to Klaviyo! Constantly having to export out a list via Google Sheets is ineffective; this should be automated :slight_smile:
@user1906 many thanks for your suggestion and for sharing your use case!
We’ll try to think about Klaviyo direct integration, but maybe our Zapier integration could help you right now?
The thing is that Zapier is available in all our Forms widgets, including Popup, so you’re very welcome to test it out :slight_smile:
You can find it on Builder tab → Form block → Integrations:
I would like to integrate my pop-ups and other applications with Klaviyo.
Hi there, Courtney :wave:
This idea is already on the Wishlist, and I’ve moved your comment to the related thread, where we’ll keep you in the loop :slightly_smiling_face:
