Klantenvertellen reviews
Add Kijoh / klantenvertellen
Hi there and welcome to the Community, @user10652 :waving_hand:
Thanks a bunch for the feedback!
We already have a request for the Kiyoh source and you can upvote it here - PLEASE add the reviews from kiyoh.com/.
As for the Klantenvertellen reviews, we’ll try to consider it in the future, especially if more users upvote it :slightly_smiling_face:
As a workaround, you can use a Custom Source option which allows adding the reviews manually:
