I have added this code because we had a request to make the search bar larger and more visible. However, now when you type in the search bar, there’s a weird “echo” effect. See the pic below. Any way to avoid this?
Hi there, @Mike_Gregory ![]()
Thanks for bringing this up!
Here is an adjusted version for changing the filter size:
.es-filter-button-button,
.es-filter-button-text {
font-size: 14px !important;
line-height: 20px !important;
And this CSS code will help you change the size of the search:
.es-search-input,
.es-search-input .es-text-control-base-placeholder,
.es-search-input .es-text-control-base-inner,
.es-search-input .es-text-control-base-input-wrapper {
Give it a try and let me know if it helped ![]()
That worked perfectly. Thanks, Max!
It’s my pleasure ![]()
