Issue with Conditional Logic Value
Hi,
I think I found a problem with the conditional logic when the value is roughly the same.
The conditional logic cannot differentiate accurately. If a new calculation is selected without reloading the page, this occurs more frequently. As if a reset function is missing.
Hi there, @Sina :wave:
Thanks for bringing this to our attention!
Could you please share more details about the case when the issue occurred (values entered, calculation results)? A screenshot would be highly appreciated :pray:
Hi @Max
It’s difficult to show this in a screenshot. But here’s an example. If I use both dropdowns to switch calculations, the results show sometimes values ​​that don’t belong there. (0.81 and 7.4+) See marking. When I reload the page it works again
after reload the page and the values in the result section are right.
I’ve managed to replicate the issue, thank you so much!
I’ve shared this info with the devs and will get back to you tomorrow :slightly_smiling_face:
Hi @Sina :wave:
This issue requires a deeper investigation! Our devs are checking things, and I’ll update you once any news comes up :slightly_smiling_face:
The fix is finally released! Please check your widget and let me know if it’s working fine now :slightly_smiling_face:
@Max i`ll test it and then mark it as solution
Hi @Max
it works well now. :slightly_smiling_face:
