Issue with Business Owner Name in Reply Modal
Hi there!
I’m using the All-in-One Reviews widget with multiple sources and have encountered an issue.
When I click “Read more” on a review, the business owner name displayed in the reply modal is incorrect — it appears to be pulled from just one source and used for all reviews.
However, when I click the link to view the full review on Google, the URL and business owner name are both correct.
Could you please look into this?
Thanks!
Hi there, @GO_Rentals :wave:
I see that my colleague Irene has reached to you and passed your request to the dev team. Irene will keep you updated :slightly_smiling_face:
Max, thank you so much! I’ll be waiting for the solution :slightly_smiling_face:
Hi there,
Just curious - are there any deadlines for fixing this defect? And do you need any additional information from me?
Thank you :slightly_smiling_face:
I see that the issue has just been resolved! Please check your widget and let me know if it’s fine now :slightly_smiling_face:
@Max Yes, it works now! Thank you! However, I noticed that it only works in the “All in One Carousel Widget” and still doesn’t work in the “All in One Grid Widget”. I’m using both, so could I please ask you to fix it in the Grid version as well? :slightly_smiling_face:
Sure, I’ve asked the devs, and they’ll apply the fix to the Grid widget too :slightly_smiling_face:
I’ll let you know once it’s done!
The global fix is released! Please check your widgets and let me know if they are fine now :slightly_smiling_face:
Yes, everything’s working now! :+1: Thanks a lot for the quick help :raising_hands:
No sweat!
In the meantime, I’d like to remind you about our Giveaway, where you can win 3 FREE months for your subscription.
Check the details and join in :wink: - April Giveaway: Celebrate 80K Members with Us & Win 3 FREE Months! :heart_eyes:
