We’ve just released an update that makes connecting Instagram Business accounts easier in our Instagram Feed app ![]()
Now, the widget uses the Instagram API with Instagram Login, so you can link your business page directly — no Facebook connection needed.
Your existing connections will remain the same, but if you reconnect the widget, you’ll be switched to the new method automatically. And for any new widgets, the new connection method is already in place ![]()
