I want to ask Location of client and city of client
Share your use case and provide as many details to support your idea as possible. Thank you! :blush:.
Hi @Arun_Kumar1 welcome to community :clap:
Could you please specify what you mean under this “ask location”? Do you want the Location field to pull the exact coordinates, e.g from Google Maps or just an address?
To query the address you need a simple Number Field (ZIP Code) and a short Text Field (City)
There are a number of templates available.
Choose one that suits you and customize it to your liking.
Templates Forms
Types of elements available with Contact Form
Hi there, @Arun_Kumar1 :wave:
I see that you’ve started using the Form Builder widget for this purpose. Does it cover your idea?
If not, please describe your use case in more detail :slightly_smiling_face:
