How to set the same height for all post cards
Hello,
I’m wondering if it’s possible to set a fixed height for the social feed so that it stays the same regardless of the content. At the moment, the feed expands or shrinks to the posts content. It would be ideal if the feed maintained a larger, consistent size, leaving some blank space for shorter posts. This would keep the layout clean and uniform on my webpage.
The feed in question can be found here: K9 Pooper Troopers – Dog Waste Removal, Sanitising & Deodorising in Adelaide – Customer Hub
Thank you and best regards,
Michael
Hi there, @Michael_Surnak :waving_hand:
Glad to say that we’ve released this feature last week for the Carousel and Grid layouts! Check this post for more details :wink: - Social Feed: Enable post height alignment
Thanks, Max. That feature didn’t resolve the issue, but I found an easy fix in Squarespace. I simply needed to set the element to be centre-aligned. Now, regardless of how much the content expands or shrinks, it stays evenly spaced between the elements above and below it.
Sorry for misunderstanding!
You’re right, this feature works only for the post cards within a widget, but doesn’t make different widgets the same height. However, I am happy to know you’ve found a solution for your use case.
If anything else comes up, we’re always here to help :wink:
