To replace a Text with Image on Mobile Squarespace, you can follow these steps.
#1. First, you need to find the ID of the Text Block. Use this tool.
In my example, it is:
- #block-fb7441e2bec4b1d3b324
#2. Use this code to Custom CSS box
@media screen and (max-width:767px) {
div#block-fb7441e2bec4b1d3b324 {
display: inline-block !important;
background-image: url(https://cdn.pixabay.com/photo/2024/07/03/08/05/hot-air-balloon-8869138_1280.jpg);
width: 250px;
height: 200px;
background-size: contain;
background-repeat: no-repeat;
background-position: center center;
div#block-fb7441e2bec4b1d3b324 * {
color: transparent !important;
#3. Result
