How to remove yellow highlight on link box
As shown on my image, im interested in removing the yellow highlight on my link box. :slightly_smiling_face:
  • Emil
Hi there, @Graphic_House and welcome to the Community :waving_hand:
Could you please specify the ID of this widget? I’ll gladly check it for you :wink:
I added a link in Adobe Acrobat :slight_smile: Dont believe its a widget like that, but I could be wrong
I am afraid I didn’t quite get your use case.
Is this logo with the yellow background a part of your Elfsight widget? If this is the case, could you please share the ID of your widget?
I have put a link box on various places in my PDF, so when the reader reads it, they can click the link and get to the URL I linked to. I made the link box in Adobe Acrobat, and when reviewing that PDF it shows invisble link boxes. But when uploaded to your serivce, the link boxes get a yellow overlay :slight_smile:
Got it, thanks!
I’ve checked your widget in the configurator and the yellow overlay doesn’t appear there:
It seems the issue occurs only upon the installation because of the conflict with the styles of your website. Could you please send me a link to the page, where your widget is installed?
Sure :slight_smile:
We’ve fixed the issue, using this code in the Custom CSS field on the Design tab of your widget’s settings:
.fb3d-link a,
.fb3d-link a:hover {
  background-color: transparent;
Please check your website and let me know if everything is fine now :slightly_smiling_face:
