To remove Underline from Links in Squarespace, you can use these
#1. Announcement Bar Underline
You can use this CSS code.
#2. Header Links Underline
You can use this code to the Custom CSS box.
div.header-nav-item *, div.container.header-menu-nav-item * {
background-image: none !important;
#3. Text Block Links Underline
div.html-block a, div.html-block a * {
text-decoration: none !important;
#4. Footer Links underline
Use this CSS code.
footer.sections {
