If you want to remove arrows from Summary Carousel on Squarespace
You can use this code to Website Tools > Custom CSS
div.summary-carousel-pager {
display: none !important;
If you want to do this for specific carousel, you can find Summary ID.
In my example, it is: #block-yui_3_17_2_1_1722512309861_3153
Next, use CSS code like this
#block-yui_3_17_2_1_1722512309861_3153 div.summary-carousel-pager {
