Want to open the AI Chatbot widget by clicking on the Button widget? We’ve got a solution!
Steps for the Button widget
Add open-ai-chat-with-button class to the installation code of your Button widget (right after the Widget ID) and install the resulted code to your website.
Here is how it will look:
<!-- Elfsight Button | Untitled Button -->
<script src="https://static.elfsight.com/platform/platform.js" async></script>
<div class="elfsight-app-WIDGET-ID open-ai-chat-with-button" data-elfsight-app-lazy></div>
Do not forget to replace WIDGET ID with the ID of your widget ![]()
Steps for the AI Chatbot widget
1. Add this code to the Custom JS field on the Settings tab of your widget’s settings:
const TRIGGER_BUTTON_SELECTOR = '.open-ai-chat-with-button button';
new Promise((res) => {
if (element) {
res(element);
observer.disconnect();
waitForElement(TRIGGER_BUTTON_SELECTOR).then((triggerBtn) => {
triggerBtn?.addEventListener('click', (e) => {
e.preventDefault();
e.stopPropagation();
const chatWindow = document.querySelector(
'[class*="widget-window__MessagesContainer-sc"]'
if (!chatWindow) {
const openChatBtn = document.querySelector(
'[class*="eapps-ai-chatbot"] [class*="FloatingButtonContainer-sc"] button'
openChatBtn?.click();
2. Hide the chat bubble using this code in the Custom CSS field on the Settings tab of your widget’s settings:
[class*="ButtonBase__ButtonContainer-sc"] {
display:none;
3. Install your AI Chatbot widget to the website
Voila! Now your chatbot is automatically opened on the Button widget click:
Guys, was this workaround helpful to you? Share your feedback in the comments below
