If you want the paragraph to not be visible unless the title is clicked, you can use Accordion Block to achieve this.
#1. First, add an Accordion Block
#2. Next, enter Title and Description
You will see have this
#3. To remove lines on top/bottom, you can use find Accordion ID
then use CSS code like this
#block-yui_3_17_2_1_1725175574269_15595 div.accordion-divider {
display: none;
You will have
and when click it
to make accordion text show full text, use this code to Custom CSS box
div.accordion-item__description {
max-width: 100% !important;
