How to change load more button border radius
Hi, I am using the code below but it’s not working, any help appreciated :slight_smile:
.es-load-more-button-container {
border-radius: 20px 0px;
Hi @Mark707, happy to see you in our community! :wave:t2:
Which widget are you trying to customize, please? I’ll be happy to look into it for you :slight_smile:
Hi Helga,
Thanks, it’s the All-in-one reviews
Thanks
Mark
Thanks, Mark!
You need to change the corner radius, right? If so, you will find this option on the widget’s Style tab → Load More Button → Corner Radius:
Let me know if it helps!
Thanks Helga, I’m trying to use a custom setting for the button to create a similar effect to the uploaded image
Oh, I see, thank you! I’ll consult with the developers and get back to you a bit later :slight_smile:
Perfect thanks :slight_smile:
We’ve added the following CSS code to your widget, and it seems it did the trick!
.es-load-more-button {
  border-radius: 20px 0px !important;
Let me know if you love the result :slight_smile:
That’s perfect thanks!
Awesome! Feel free to contact us here, we’re always happy to help :smiling_face:
By the way, make sure to check out our ongoing Giveaway where you can win 1 FREE YEAR: BF 2024 Giveaway: Win 1 YEAR of Free Usage (10 Winners) + guaranteed month! :star_struck:
