To add Twitter Feed to Squarespace, you will need to use 3rd party tool. In this post, we will use this free tool.
#1. First, install the Twitter Feed free widget.
#2. Choose a desired layout and click Continue with this template
#3. Connect with your Twitter account
#4. Enter your info to log in to Twitter
#5. Click Authorize app
#6. You can close the popup
#7. Choose Content to display. The layout will appear on the right side.
#8. You can adjust some options in Layout, Style…to achieve the layout/style that you want.
#9. Then click Add to website for free
#10. Click Publish
#11. Choose Free Plan then click Copy embed code
#12. Edit page where you want to add Twitter Feed > Add a Code Block
#13. Paste Twitter Feed embed code
#14. Save. And see the result.
