To add same information into Additional Info of all products, you can do these.
#1. Create a Page in Not Linked.
Use Name/URL: Saved Section – /saved
#2. Next, design the page. Here I use a simple design.
#3. Use this code to Code Injection > Header
<div data-wm-plugin="load" data-target="/saved"></div>
#4. Use this code to Code Injection > Footer
document.addEventListener('wmSectionLoader:scriptsLoaded', () => {
const loadContainer = document.querySelector('div.wm-load-container');
const targetSection = document.querySelector('section.ProductItem-summary');
if (loadContainer && targetSection) {
targetSection.after(loadContainer);
#5. Install this plugin
and Footer
