To add a dropdown for prices “High to Low” or “Low to High”, you can follow these.
#1. Use this Filter Plugin
#2. Open Filter Documentation Page, you will see a line like this in Step 2.
#3. Hover on Shop/Store Page > Click the Gear icon
#4. Click Advanced > Page Header Code Injection
#5. Paste code you have in #2
#6. You will see Get Filter Config button > Click on It
#7. Click Copy Code
#8. Replace #5 code with #7 code
#9. You will see a result like this
#10. To remove Category, Tag, Availability, Search and keep price Low to High or High to Low only
You can use this to Custom CSS box.
div.filterDropdown.name-Category, div.filterDropdown.name-Tags, .filterDropdown.name-Availability, .custom-items-search {
display: none !important;
.sortDropdown ul>li:not(.price_asc):not(.price_desc) {
display: none;
Result
