How can I auto-open a Form Builder?
Thank you
Thank you
Hi there, @Luis_Carlos_Barragan ![]()
Please try to add this code to the Custom JS field on the Settings tab of your widget’s settings:
const buttonSelector = ".es-forms-floating-button";
const listenDelay = 100;
const listenLimit = 500;
function listenForElement(elem, selector, delay, step, limit, resolve, reject = () => { }) {
elem = document.querySelector(selector);
if (!elem) {
step++;
if (step < limit)
setTimeout(() => {
listenForElement(elem, selector, delay, step, limit, resolve, reject);
}, delay);
else
reject();
else {
resolve(elem);
function onButtonFound(button) {
button.click();
window.addEventListener("load", () => {
let button;
let step = 0;
listenForElement(button, buttonSelector, listenDelay, step, listenLimit, onButtonFound);
Check it out and let me know if it worked ![]()
Hi Max, this is not working for me
Could you help me to check please?
Regards
I see that you’ve already contacted my colleague Danis, and he’s forwarded your request to the devs. Danis will keep you updated ![]()
