Hide slider on mobile
Hi,
how can I hide my slider on mobile?
THanks and BR
Hi there, @B.S :waving_hand:
Here is the code to hide the widget on mobile:
@media (max-width: 480px) {
	.global-styles,
	.elfsight-app-WIDGET_ID {
		display: none;
Replace WIDGET_ID with the ID of your widget and add this code to the Custom CSS field on the Settings tab of your widget’s settings :slightly_smiling_face:
@Max awesome code but the question would also be “Hide Widget on mobile”. :blush:
It would be nice if it found a place in the CSS code section.
Hey there, @Sina :waving_hand:
This code should for all widgets, not just the Slider :slightly_smiling_face:
I agree that it would be awesome to add this code to the CSS Codes section, but since its categories are app-specific and this code works for all apps, I’ve added it to the Pro Tips category - How to hide a widget on mobile
