Hide Attachment button
Add this code to the Custom CSS field on the Settings tab of your AI Chatbot widget’s settings
.es-interaction-field-attach-button {
  display:none!important;
Not working :pensive_face:
Hi @Adri :waving_hand:
Thanks for flagging this up!
Here is a slightly adjusted version that will do the trick:
Max with my widget below this code doesn’t work
Hi there, @user23472 :waving_hand:
This and other codes added to your widgets don’t work because of the wrong comments format:
If you’d like to add comments to the codes, please use the format below. Give it a try and let me know if it helped :slightly_smiling_face:
/* Comment */
Refresh the several times but got
As far as I see, you didn’t remove the incorrect part of the code from your widget:
I’ve removed it from the widget and now the code is working fine:
Please check it out :slightly_smiling_face:
