option to cancel AI rating in the mobile version
Thank you for this suggestion, @Artur_Narusevic!
Although there is no built-in option to hide an AI Summary post for mobile devices, we’ve put together CSS codes to help you with that
Depending on the layout, choose the CSS code and it to Custom CSS field on your widget Style tab:
Grid Layout
@media(max-width: 600px) {
.es-grid-layout > *:first-child {
display: none !important;
Masonry
.es-masonry-layout > *:first-child {
.es-header-component-top {
margin-bottom: 0;
List
.es-list-layout > *:first-child {
Unfortunately, it won’t work smoothly with the Carousel layout, so I didn’t post it here. Hope it helps!
