Help with customization
How can we customised the:
Read more text (to CAPS and Bold)
Background of the read more pop up box
Wrap text of reviewer to a second line if too long?
Hi there and welcome to the Community @user23721 :waving_hand:
Sure! The CSS codes below should do the trick :backhand_index_pointing_down:
Read More text (Caps and bold)
.es-review-content-control {
  font-weight: bold;
  text-transform: uppercase;
Popup background color
.es-popup-content-container {
  background:green!important;
As for the reviewer name wrapping, could you please specify the maximum number of characters you’d like to display on the 1st line?
Thanks Max! I appreciate your help!
Read more text caps and bold works perfectly - thank you
The popup background color is also great! (am I able to remove the reviewer name and logo from this pop up box?
For the reviewer name wrapper, probably about 35 characters if possible?
Unfortunately, there is no way to set a specific number of characters, but you can set a max width for the author review name container:
.es-review-author-name {
  max-width: 250px;
  text-overflow: unset;
  white-space: wrap;
And here is the code to hide the logo and author name from the popup:
.es-popup-content-container .es-review-author-name,
.es-popup-content-container .es-review-info-company-logo {
display: none;
Please try it out and let me know if it helped :slightly_smiling_face:
